I couldn't find an answer after searching the forum... what tools are needed for valve adjustment? besides feeler gauges... i went on bma and found vavle adj. screw & other vavle adj things.. i wonder if I'll need those... thanks for your help!
valve adjustment tools
Tags: None
10mm ratchet, allen wrench, feeler guages. The list is short and simple. Might want to replace the valve cover gasket as well while you tackling this.Back to my roots
You'll want to make sure you torque the valve cover nuts too.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
Old age and treachery will always overcome youth and skill.
on a similar topic... i think one of the studs where the valve cover is bolted on is stipped. it hasnt broken off i just cant get it to tighten any more. my question is are these studs pressed in, welded in, screwed in, replaceable, all that jazzYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
Originally posted by NC325iCon a similar topic... i think one of the studs where the valve cover is bolted on is stipped. it hasnt broken off i just cant get it to tighten any more. my question is are these studs pressed in, welded in, screwed in, replaceable, all that jazzComment
Are they better than helicoils?
ummm you guys are forgetting that you need a 30mm socket on the harmonic balancer to turn the cam. Another option is to bump the engine over with the starter i guess.
'89 Alpine S52 with goodiesComment
they make devices with a button you attach to the starter so you can just do it from the engine bay. they're like ten bucksOriginally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
Plan on replacing your sparkplugs at the same time.
Remove all sparkplugs.
I make a tool out of an eight penny nail and my grinder every time.
I also have a few new eccentrics and the nut with bolt handy.
They are cheap- eccentrics are $3.20 the bolt and nut run about $2.60.
When you have a hard time getting an adjustment correct, if often means someone ran the car too long with the valves out of adjustment. The eccentrics can develop a flat spot.
Forget trying to use the starter.
The Bentley tells you an order to go through when you adjust your valves.
Use it and you will find it can be done Quickly.
Go through the order adjust them using a large socket and ratchet.
Then turn the engine over for a short time, and check your adjustments again.
If you have one that keeps going out of adjustment ,it could be a bad eccentric.
Replace it! I always replace the nut and bolt also.
There is nothing worse than sealing down a brand new valve cover gasket, then a minute later hearing-tap tap tap
like you never even adjusted the suckers.Comment
Try this:
Go to Radio Shack, buy the cheapest momentary contact pushbutton they have, like $2.00. Solder on about 3 feet of speaker wire, like 18 guage. Strip the other end, and solder that so you have a "pin".
Open your diagnostic connector AFTER looking at the unoffical BMW guide...stuff that "pin" into the connectors labeled "starter" and 12 volts (AKA "Battery")
MAKE SURE YOU ARE IN NEUTRAL!!!!
Tap that little button and your starter cranks over. Way easier than any other method.
Also, an 1/8" drillbit is the best tool to rotate that eccentric that I have found.
GL!
LukeComment
