Hit a bump and the engine drops to idle
  • MlTCHELL
    • Jul 2015
    • 2
    I have an 84 with an M10, mostly unmolested.
    Recently, whenever I hit a hard bump, the car loses all power, but will keep idling, and rev to 1500 RPM like normal, but won't go over 1500ish. One key-cycle fixes the issue.
    Imagine driving down the freeway and then you hit new pavement, and the whole car feels like it is turned off, but if you push in the clutch, the engine isn't really dead, it just has zero power. Then, pull over, turn off, turn on, and you're back like nothing ever happened.
    Any ideas?
  • Kershaw
    • 11822
    Have you checked your main engine ground?
    AWD > RWD
    • MlTCHELL
      • Jul 2015
      • 2
      Yeah, it's solid. Definitely not the ground. Today, after it happened, I actually had a hard time getting it running again. Kept restarting and not wanting to rev at all.
      Sent from my SAMSUNG-SGH-I537 using Tapatalk
