How can I check my coolant mixture?
  • Das Delfin
    • Sep 2014
    • 2293
    Other than draining everything and measuring out a new mixture. I think I have too much coolant in the mix
  • Dirty325ix
    • Sep 2012
    • 689
    You can go to any auto parts store and get a little tester kit for less than 5$
    Suck a little of your hopefully coolant into the tester and it will let you know (normally a bunch of balls that only float at specific mixtures)
    • efficient
      • Feb 2012
      • 3312
      They sell a thing at Walmart that has little balls inside/or one that has indicator arrows and it tells you the strengths .
      • AndrewBird
        The Mad Scientist
        • 11898
        It's called a hydrometer:
        And yes, they are very cheap.
        • Das Delfin
          • Sep 2014
          • 2293
          ^ that's what I want!
          • mickTom
            • Sep 2015
            • 2
            Keeping a proper coolant mixture is vital to your car's health. Antifreeze should be close to a 50 percent mixture, depending on your climate and driving conditions. But how are you supposed to know whether your coolant mixture is right for you and your car? You can test your coolant mixture easily with an inexpensive coolant mixture tester that can be bought at any auto parts store.
            Top Ten classified website
            • McGyver
              • 4636
              Fucking solid recap and decent info spambot mickTom! Maybe spambots will be the future of tl;dr threads?
