left post on starter solenoid not delivering power
  • jeffw
    • 1087
    So as the title says the left post on the starter solenoid is not delivering power to the starter. When I jumper the two posts the starter spins. What is the first thing I should do to backtrack this problem.
    From memory, that wire goes straight to the ignition switch.
    • jeffw
      • 1087
      so It either broke or got pulled out?
      • jeffw
        • 1087
        bump
        • dnguyen1963
          • Nov 2011
          • 2651
          Have someone turn the key to start and you check for voltage at the starter. Check for continuity of the wire from the ignition switch to the starter. If you are getting continuity and no voltage then it is time for a new ignition switch.
