How hot is too hot with an M20?
  • ptownTSI
    • Jun 2005
    • 1265
    I dont trust the factory temp needle, it shows that my 325is is going to 3/4 up the gauge once i've been driving for a half hour or so. i'd like to install an autometer water temp gauge. how hot is too hot where i should pull over and let the car cool off? 220? 225?
  • Jand3rson
    • 37587
    If it's moving steadily out of the 3/4 range and toward the red, pull over and turn off the car. Sounds like you might need a new water pump, or maybe just a thermostat.
    • ptownTSI
      • Jun 2005
      • 1265
      it hasnt gotten to the red range ever. i have a brand new FAG waterpump. i'll change the thermostat when i do my 3000 cfm e-fan conversion with dual speeds, A/C on/off, and fully manual operation.
      • Ryan Stewart
        I Love Miatas
        • 8978
        Mine only got above half when the clutch on the fan was shot. Replaced it and it never got above half.
        Im now E30less.
        • h0lmes
          lol FAG waterpump. godddamit im drunk
          • ddongbap
            • Sep 2005
            • 248
            I was running no thermostat for a while. Cause it was stuck open. It NEVER past the first notch. Even in 90degree weather. Now it sits right before half. As it should.
            My drinking team, has a racing problem.
            Anyone have an aquarium? If you want fish, let me know.
            • Ryan Stewart
              I Love Miatas
              • 8978
              Originally posted by h0lmes
              lol FAG waterpump. godddamit im an idiot.
              You sure got that right!
              Im now E30less.
              • yozsi
                • Feb 2006
                • 337
                mine will creep above 1/2 if im idleing around, but as soon as i bring it above idle and hear the fan run the needle drops back down.
                Unlimited Slip Diff's FTW!
                1972 240z Drift,Scca BSP, Scca ITS Car.
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  ...damn...i had to wire up my aux fan up to direct power to get it to cool my car...90degree day if i idle for more than 5 minutes my car starts going past 3/4....the old 318is i had just fuckin sits in the red at the end as i drove it down the street for 10 minutes....it was about 95 degrees then....
                  bad thermostats?
                  • jbsjunk
                    • 477
                    Mine ran 1/2-3/4 on the gauge, ends up my rad was getting really plugged in the fins between the condenser and rad, dirt, fuzz, etc.
                    • trashcop 80s 80s
                      • Jun 2004
                      • 1130
                      Be careful. I popped a headgasket with only getting to the 3/4 mark. 17 years plus 180k on a headgasket and they will fail pretty easily.
                      • Digitalwave
                        is a poseur
                        • 6300
                        Your car shouldn't go above 1/2 as long as everything functions correctly. If you continue to run the car at the 3/4 mark you are going to blow your headgasket sooner or later, and possibly do more damage such as cracking or warping the head.
                        RISING EDGE
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          He isn't asking if that is too hot or not, he is asking what temperature is too hot because he doesn't trust that his stock gauge is correct.
                          ptown, do you have a Bentley? It should say in there what temp is normal operating temp.
                          • ptownTSI
                            • Jun 2005
                            • 1265
                            yeah i do have a bentley.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              i dont thing ive seen mine get anywhere near going past half, and i took out my clutch fan, i just run the aux fan
