Exhaust manifold nuts! any tips on getting these things off?
  • audiquattrot
    • May 2008
    • 3836
    having a hell of a time trying to get a socket for the lower nuts (under the manifold).
    tried regular wrench w another wrench mated to it for leverage, and the wrench keeps slipping off the nut.
    Doused the nuts w PB blaster, and gonna give it another go tonight. Socket wrench doesn't seem to clear the manifold for a couple of the nuts underneath either.
    tips on how you guys got these out?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • 5Toes
    • 9836
    I just installed the exhaust on my m20b25 the other day. I used a 12mm combination wrench, but I used fresh studs and bolts - yours are pretty crusty huh?
    2/3 of the nuts are accessible with a socket wrench using the right combo of extensions.
    as far as under the manifold the two nuts closest to the front I used a socket, the other 4 I use a wrench.
    a socket wrench is going to give you alot more leverage so do what you can to slip one in there, maybe use wobble extensions.
    good luck! dont round them off bud! new nuts and studs are only about $12-15
    • audiquattrot
      • May 2008
      • 3836
      Thanks man. I really wish I could fit a breaker bar in there. I wonder if being I have an iX (front subframe etc), its making it more difficult as far as room from underneath
      I bought all new studs and nuts....although I do have a feeling I might strip a couple of these old ones....which i'm not sure how I'll get out if I do!
      #snwmble
      Current:
      Past:
      • 5Toes
        • 9836
        yeah DONT strip them. 6pt sockets only here!
        maybe even a 1/4" drive socket with a 3/8 adapter to gain a little extra clearance. get creative!
        • TobyB
          • 5280
          I once welded a long bar onto a nice 12mm box end for just this-
          getting the right angle's tricky...
          t
          • audiquattrot
            • May 2008
            • 3836
            Well I stripped two underneath. All the other ones above came out wo a hitch. Now what lol.
            I'm so screwed. Got anxious and tried to grab it w vice grips and still no bueno
            #snwmble
            Current:
            Past:
            • 5Toes
              • 9836
              shit.
              hopefully one of the extractor sockets will work for it?
              which two are the stripped ones.
              just unbolt the down pipes and pull the head off!!! :)
              • audiquattrot
                • May 2008
                • 3836
                I'm gonna see if I can scoop up one of those extractor sockets at harbor freight. The two I stripped were the two nuts under the 4th and 5th cylinder.
                #snwmble
                Current:
                Past:
                • doorman
                  • Mar 2015
                  • 360
                  I've used the Irwin brand stripped nut/bolt extractor. I used them on the Allen boots on the diff/cv axle connection that someone stripped.
                  About $40 for the set I believe.
                  You do have to pound them on a bit first.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    I'm late to this one, but the accepted and proper way to do it is with a 1/4" drive breaker bar. It can also be done with a 1/4" ratchet if they aren't too uckfayed. The Vice grip thing may work, but will likely pull the stud out as well cause when you grab it with them, it effectively locks the nut to the stud. Good luck guy.
                    Originally posted by Andy.B
                    I was born on 3/25…
                    • 5Toes
                      • 9836
                      1/4" breaker bar now theres a good idea. will pick one up at HF for next time to try it out :)
                      • efficient
                        • Feb 2012
                        • 3312
                        My nut/thread spins when I loosen it. -__-
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          dremel. I had the same problem, but only one was a bitch. Dremel the nut in two places, pry the cut section out, then wiggle the manifold if the other half doesn't come free. You might mess up the studs a bit but the tiny cut into mine wasn't a problem. Could be a good time to replace those two studs too =)
                          Lots and lots of PB blaster too. wear safety glasses and be careful because shit is probably going to fall into your face.
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • jaywood
                            • Jul 2010
                            • 4528
                            Pull the manifold from the head
                            • 101
                              • Jul 2011
                              • 764
                              ^^^ exactly what I had to do.
                              I had two stuck nuts on my IX when I did the exhaust manifold gaskets as well. I think they were the same ones you're having trouble with (#4 and #5, bottom). They were so old and rusted they were no longer the correct size, and the more I tried to get them off, the rounder they got.
                              Going back on, I used all new studs, new BMW copper coated nuts and anti-seize on the threads. Hopefully that makes it easier on the next guy.
                              101
                              The E30 collection:
                              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                              1987 325is - Delphin / Black Sport (son #3's)
                              1987 325i Convertible - Triple Black
                              1989 325iX Coupe - Diamondschwarz / Black Comfort
                              1990 325iX Coupe - Sterling Silver / Grey Sport
                              1981 Fiat 124 Spider 2000 - Green / Tan
                              1998 Volvo V70 GLT - White / Tan
                              1998 Volvo S70 T5 manual - White / Taupe
                              2001 Ford Windstar - Silver / Grey (parts hauler)
                              2006 Lexus GX470 - White / Tan (tow rig)
