Coolant flush necessary after water pump replacement?
  • FunkySwerve
    • Feb 2015
    • 43
    As the title states: do I need to flush my coolant after I've replaced the water pump? The coolant looked like new when I collected it. I put a sample in a jar and there weren't any debris or anything of that nature.
  • AndrewBird
    The Mad Scientist
    • 11898
    If you replaced it recently, you can re-use it. Filter it with a coffee filter before you pour it back in. Otherwise, I'd replace it with new. It's cheap and then you don't have to worry.
    No need to flush it or anything though. Just close everything back up and fill with a 50/50 mixture.
    • FunkySwerve
      • Feb 2015
      • 43
      Thank you Andrew! On a related note...I replaced my coolant temp. sensor, I reckon I may have to bleed it a little?
      • dnguyen1963
        • Nov 2011
        • 2651
        Always bleed the system whenever you mess around with it. Follow the sticky procedure by jlevie.
        • FunkySwerve
          • Feb 2015
          • 43
          Another problem I'm running into is that my car is on a small incline, would I just have to jack it up a little higher to flush and bleed the system?
          • rcsoundn1
            • Nov 2012
            • 3361
            Some might argue that if the front is slightly up the air may more easily rise to the top. On my civic, not making a comparison here, it has to be on an incline to bleed correctly from what the "experts" say.
            • dnguyen1963
              • Nov 2011
              • 2651
              You really need to read the sticky before posting anymore question.
              • agent
                Vice Grand Pubaa
                • 7960
                This sticky:
                Originally posted by kronus
                • FunkySwerve
                  • Feb 2015
                  • 43
                  I did Nguyen, my questions are very specific and thusly was not covered in J's post. That is not to say it wasn't informative, I look to his sticky for many answers, but on questions like mine I seek help from people who are helpful.
                  • TobyB
                    • 5296
                    I'm not helpful, but on my car, getting the nose up 4" makes it go a bit quicker.
                    And if the coolant's more than a year or so old, I replace it. It's the anti- corrosion
                    that makes it so good...
                    t
