grinding during sharp turns
  • Lucas.B
    • Jul 2005
    • 115
    Hello,
    Just wondering if you guys could help me out. It started from the front drivers side, during sharp turns, there is a nasty grinding noise, just when the wheel is fully, or close to fully cranked. It has now started to do the same on the passengers side. Exaclty what part(s) must be replaced?
    Thanks so much for any input/help
    Luke
  • Mike325
    • Mar 2006
    • 3685
    Could be the P/S pump failing. Does it do it when you are moving or when you are stopped? Possibly the rack too, but most likely not. Check the level of P/S fluid in your resevuair (spelling?)
    Originally posted by Kershaw
    • mtechnik
      • 6156
      reservoir :D .. You make it sound so.."debonair" Mike325
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        Not a bearing is it?
        Yours truly,
        Rich
        you kids get off my lawn.....
        • Lucas.B
          • Jul 2005
          • 115
          Thanks a lot for all the input
          yeah, it only happens when I'm moving
          • AndrewBird
            The Mad Scientist
            • 11897
            Do you have stock wheels? Wrong sizing/offset could cause aftermarket wheels to rub at full lock. In my MG, even with the stock size wheels, my aftermarket aluminum ones rub the tie-rod at full lock.
            • Lucas.B
              • Jul 2005
              • 115
              Nitro, they are stock bottle caps, but they do have 15 mm spacers in each corner. It is my friends car by the way.
              Thanks again
              • emi
                • Jun 2005
                • 80
                I had that happen on stock wheels... the fender liner in front of the wheel came loose and started rubbing the tire. it was bad in reverse.
                • Van Westervelt
                  • 9365
                  One of mine just started that. Except its more of a click or a pop with every revolution of the wheel instead of a grind. Isnt that notorious of the bearing?
