Wideband sensor question
  • ky0u
    • Dec 2012
    • 808
    Hey r3v, was doing some research regarding a wideband o2 sensor and was wondering if the Innovate LSU4.2 would work on my car.
    I've been digging around looking to see what I need to make the switch because I would like to install an AFR gauge but what keeps popping up is the megasquirt pnp unit or the Innovate LC-1
    Web Designer / Front End Developer
    My Portfolio & Website
    IG: @w_illriderz
  • bmwstudent
    • Sep 2011
    • 1364
    aem makes a nice unit, i have one and i like it. Nice quality, nice harness, works great, no calibration necessary
    • ky0u
      • Dec 2012
      • 808
      I would, but I wanna pair it to a custom AFR gauge that I can pop into my stock hvac panel
      IG: @w_illriderz
      • bmwstudent
        • Sep 2011
        • 1364
        i think someone on this board makes a little gauge that fits into the speaker fade control spot.
        • ak-
          • 12422
          You can install an afr gauge separate from your narrowband o2 and let it function on its own for readings.
          1991 325iS turbo
          • ky0u
            • Dec 2012
            • 808
            Yea, I believe it's George graves that makes them. But idk if he's still doing them. I haven't been on here in a while, I gotta shoot him a PM
            The afr gauges that work with a narrowband are the led indicator type aren't they? The ones that show actual numbers only worked with the wideband input I thought
            IG: @w_illriderz
            • ak-
              • 12422
              Right, and there is a complicated annoying way that everyone in he world has trouble with to splice in the wideband afr into your motronic so that it replaces the narrowband as a whole and function as your only o2, but the success rate is low.
              I originally had a divorced setup with my narrowband functioning on its own giving intfo when my car was turbo on a draw-thru setup. Had the wideband reading me AFR on its own for my sanity.
              Now since I'm on Megasquirt, my wideband replaced it entirely as Megasquirt has an input for it in when you connect a single wire to your original o2 wiring.
              1991 325iS turbo
              • george graves
                • 20003
                That's correct. Just think of it this way....A narrowband sensor has two values it can output. Rich or lean. It's doesn't know anything in between. (Turns out that works great for a stock ECU)
                Widebands actually show numbers - and they mean something. You can say "My AFR is 12 and it should be 14 something" - it's something you can measure.
                Right, and there is a complicated annoying way that everyone in he world has trouble with to splice in the wideband afr into your motronic...
                There isn't much advantage to running one wideband and having it simulate a narrowband and fedding that into your stock ECU IMHO (other then the $40 it costs to get a second bung welded up). Just more things to go wrong. So for people that have a factory ECU or a factory ECU with a chip(non-megasquirt kind of people) then keep your narrow band and add a wideband "divorced" as AK calls it (totally separate). That way you can an eye on your expensive motor swap, and your factory ecu/chip will be totally happy with it's good-running, tried-and-true, narrowband at the same time.
                Yea, I still make them. I was going to take a order for a small batch of them soon. PM me if you want to get to the front of the line.
                Originally posted by Matt-B
                • ky0u
                  • Dec 2012
                  • 808
                  Can someone explain the divorced set up? Is there then 2 sensors? One for the ecu and one for just the gauge?
                  IG: @w_illriderz
                  • george graves
                    • 20003
                    Yep - you got it. The "divorced" set up you want looks like this:
                    Wideband sensor-->--wideband controler--->--gauge.
                    Narrowband sensor--->--ecu.
                    • digger
                      • Nov 2005
                      • 6199
                      you want this with the NTK sensor much better than LSU 4.2
                      i know many pro tuners recommend this as great BFYB, they wouldnt touch cheap innovate crap.
                      i use it and its excellent
                      • george graves
                        • 20003
                        ^lol Never even heard of those guys. And it's not even programmable and seems to only have one output. I'll stick with innovate - you can get a full set up on ebay for $150. www.ebay.com/itm/400907148279
                        • ak-
                          • 12422
                          Innovative has worked for my car for the past few years. I've killed 1 sensor though from immense blow-by when I hurt my motor long ago, but the sensor comes from a VW Turbo Beetle(?), so it's not really a variable in my review.
                          My tuner also uses innovate
                          1991 325iS turbo
                          • Coupelx
                            • Oct 2013
                            • 169
                            I think most factory ECU's have issues with the narrow band signal produced by a wideband. I could never it to work on my turbo moostang either.
                            I am currently working on mounting one of these where the 'Check" light is in the cluster. its a perfect fit for the hole and accepts a serial input. It is designed for their controller but ive read somewhere it may work with whatever wideband you have that has a serial output (most all do except the 14point7.com stuff i think)
