7k cluster vdo question
  • JeLani
    • Aug 2015
    • 1552
    Where does the coding plug go to on here?
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
  • reelizmpro
    • 9542
    So you know...this is an 84 318i cluster. 84-85 318i/325e clusters use a black plastic coded peg in back of the tach instead of an electronic chip. SI board is different as well. It won't be accurate if you're trying to use it on a 325i.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • JeLani
      • Aug 2015
      • 1552
      I dont think the guy who sold me the 2.7i even knew to be honest, this was going into my 325e , so it wont be accurate?
      1998 e36 328ic/5 -
      1967 2002 parts car
      1994 318iS junked.
      • JeLani
        • Aug 2015
        • 1552
        So i cant use my early 'is' chip on this?
        Edit: no i can't so i'll have to get a 325i one, are the coding plugs interchangeable between i/is models?
        1998 e36 328ic/5 -
        1967 2002 parts car
        1994 318iS junked.
        • reelizmpro
          • 9542
          I or is doesn't matter. They are the same.
          88 M3 - LACHSSILBER
          • JeLani
            • Aug 2015
            • 1552
            Ok thanks
            1998 e36 328ic/5 -
            1967 2002 parts car
            1994 318iS junked.
