wire up manual High switch for e-fan?
  • ptownTSI
    • Jun 2005
    • 1265
    on my other car you could put a grounded switch to one of the relay leads and the fan would become manual as well as automatic. how can i do this with the e30 aux fan?
  • ptownTSI
    • Jun 2005
    • 1265
    well if it turns on when you jumper thei believe its green/black to black/brown then i just need to connect a switch to these for my high manual on-off switch.
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      Did you just answer your own question?
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • ptownTSI
        • Jun 2005
        • 1265
        yeah but i'd like a way to do it through the relay its safer and fused.
        • AndrewBird
          The Mad Scientist
          • 11898
          Does the relay ground the fan or give it power? Either, way, just set the switch up so that when turned on it grounds/powers the wire coming off the relay going to the fan. THen it will still work automatically, but you can turn it on when ever you want.
          • ptownTSI
            • Jun 2005
            • 1265
            i looked in the bentley and i couldnt find a schematic wiring diagram of the relays to the fans. i thought the bentley had everything but it doesnt really have much stuff compared to my grand cherokee factory service manual.
            • 92 mtechnic cabrio
              • 4907
              well, the bentley isn't a factory service manual
              you want a factory service manual for your E30
              R.I.P 07/01/09 - 04/23/10 :(
              • ptownTSI
                • Jun 2005
                • 1265
                does anyone with a Factory Service Manual feel kind enough to scan the schematic for the wiring for the fan relays. i'd do it for a jeep forum guy!!
                • Garageaholic
                  • Dec 2005
                  • 5204
                  i didtn' even know that a "factory service manual" was available for public use really
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  • DaN
                    • 1265
                    Just wire up switched 12v to pin 86 of either the high speed or low speed aux fan relays. The low current side is much better for this, let the relays do the high current switching.
                    • Jand3rson
                      • 37587
                      It's not. They're generally found on ebay. The last FSM for the E30 that I saw on ebay went for over $300.
                      • ptownTSI
                        • Jun 2005
                        • 1265
                        all of the chrysler ones are available for $80 from the publisher (techauthority) and sell on ebay all the time for $30-$60. its about 3 1/2 inches thick for my 1998 jeep grand cherokee one. and it doesnt even include the powertrain diagnostics computer manual (but you need a $3000 computer to use it anyways)
