Well I have tried to remove the fan clutch like a normal civilized person but it still won't budge. I decided to take it to a new level since I have a new water pump on the way and a Milwaukee sawzall in the garage. I'll post up some pictures in the morning after I take it off. I can do a write-up if anyone is interested :drink:
Easy way to remove fan clutch
yeah sure am, I have taken quite a few off before. But I can't get the one on my car free. I have a replacement waterpump so its not like its going to matter if I chop it off. I'm going to replace the fan w/ an electric one also. So it won't be a prob. ;)Originally posted by ///M.FirestormYou are aware that the 32mm nut is left hand thread?///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
sawzall :D: : 1984 318i : : PNW E30 Crew : : Sold!!
Now becoming the R3vlimited Pro3 car
http://www.r3vlimited.com/board/showthread.php?t=93780Comment
Try this - an old shop trick & works evert time. Use an air powered muffler gun (in & out motion, similar to a drill driver but doesn't spin) with a chisel point blade - place it on the a flat surface of the nut, pick a surface that will unscrew it in the "off" direction. Pull the trigger while holding the chisel point firmly against it. A couple of spurts with the gun & it will be loose enough to take a wrench & finish removing it. It will slightly mar the flat surface of the nut, but not near as bad as the rounded edges you've already made with a wrench. If you don't have one or can't borrow one, take the car to a local muffler shop & have them do it - remember, you only want to break the nut loose - then follow with the wrench.[IComment
Thats good advice, works really well. Sucks when they put it back on with an air hammer thoughOriginally posted by cactusjacks1Try this - an old shop trick & works evert time. Use an air powered muffler gun (in & out motion, similar to a drill driver but doesn't spin) with a chisel point blade - place it on the a flat surface of the nut, pick a surface that will unscrew it in the "off" direction. Pull the trigger while holding the chisel point firmly against it. A couple of spurts with the gun & it will be loose enough to take a wrench & finish removing it. It will slightly mar the flat surface of the nut, but not near as bad as the rounded edges you've already made with a wrench. If you don't have one or can't borrow one, take the car to a local muffler shop & have them do it - remember, you only want to break the nut loose - then follow with the wrench.Comment
