E30 Bulkhead foam gasket replacement
  • e30fanaticz
    • Mar 2012
    • 7
    NEED HELP..
    can anyone please tell me how to properly replace the bulkhead foam gasket. the dash is currently out. i am replacing both gaskets on the bulkhead but i am nervous about the one that goes to the outside of the car because if done wrong it can cause the car to leak water and i would have to pull everything off again. i cannot find any tips about replacing it or making sure it will not leak after being replaced. thanks in advance.
  • BlackSpeed66
    • Apr 2008
    • 618
    By bulkhead do you mean the metal cover for the blower motor opening near the back of the engine? On mine, I cleaned all the dry rotted gasket off and found a roll of adhesive-backed foam in the HVAC section at Lowe's/Home Depot. I cut it to fit and it seems to have been fine since. I vaguely remember seeing it available on realoem with a factory part number. Might want to search there and see if you can order it.
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '02 Range Rover 4.6 HSE
    '98 Disco 1
    • TimeMachinE30
      • Jun 2014
      • 3749
      Yes, visit your local hardware store for a similar item.
      ACS S3 Build / Dinan 5 E34
      • jeffnhiscars
        • Jun 2011
        • 6010
        I'm not sure about the hvac to firewall gasket but the dash to hvac gasket seems to be nla. I've been waiting months for 2'so will go the Home Depot route. I suggest using epdm which will far outlast your basic foam
        Alice the Time Capsule
        • Jordan
          • 12913
          Do you mean the large foam gasket that seals the IHKS to the firewall? It and the IHKA to dash duct gasket are perfectly available, I just ordered both for my car...
          #2 and #3
          http://www.realoem.com/bmw/enUS/show...diagId=64_1719
          I would not cheap out and go the Home Depot route, maybe with the duct gasket but certainly not with the one that seals the IHKS to the firewall. It is routinely under water in the rain and you want an assured seal.
          https://mtechniqueabs.com/
          • agent
            Vice Grand Pubaa
            • 7960
            It's been a while but I got one for Klaus too, either from Blunt or BMW Schererville.
            Originally posted by kronus
            • jeffnhiscars
              • Jun 2011
              • 6010
              I'll kick my parts guy in the butt. Thanks
              • jeffnhiscars
                • Jun 2011
                • 6010
                Once the dash is out, how much more work is it to drop the hvac unit and replace the bulkhead foam ?
                Can it just be loosened and work in a new gasket (which would require a cut and reglue I'm sure) ?
                • fitswell
                  • Nov 2008
                  • 224
                  not to revive a dead thread but this is a good question
                  01.5 S4 Avant - Sold
                  88 325iS - In pieces
                  91 e34 - Totaled by some dumbass
                  90 325i - Daily
                  06 e91 - Sold
                  feedback thread
                  • Rev Run D
                    • Feb 2013
                    • 392
                    looks like it.
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      You don't need to remove the hvac unit to replace the foam. Once the dash is out it just sitting there. It's also a good idea to refoam the flaps. You can use a roll of weather stripping...just be careful not to break any of the flaps as they are brittle.
