id check the bulbs for the rest of the SI lights. assuming your are not talking about the oil change interval lights.
Vdo 7k swap problems
-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good looking
I'm talking about these lights . Green
And also only half of it lights up when i pull the lights.
The anti lock and the brake lining not being on in key setting 2 i believe is because the cluster did not have the two prongs the wire connect to. Could this affect battery life in any way such as a dead battery light? I already had the anti lock sign in my old one but that may be because it needs a new sensor?
Sent from my iPhone using Tapatalk1986 LTW M52 (First project 2015- )
1998 e36 328ic/5 -
Roundie alpina pig cheek’d (1969)
1967 2002 parts car
1994 318iS junked.
The only thing that happens when i smack it is these lights will occasionally turn off and back on
The rpms and mpg guage on another note, will hop. But nothing really.
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
but id disregard any of the lights at the moment thats not nothing to worry about at the moment the tach working is and the oil pressure light I would have just open both clusters and just swap the tachometer itself and kept the original cluster in and just swap the coding plugs lol there are differences in cluster but I cant remember what can be swapped and what cant be and I dont feel like digging my box out of clusters at the moment
Well theyre different manufacturers, the one thats in is a VDO and the eta one is a Moto. Are you telling me to put my eta plug into the i one? I have another i one lying around too .
Originally posted by alpineE30 View Postbut id disregard any of the lights at the moment thats not nothing to worry about at the moment the tach working is and the oil pressure light I would have just open both clusters and just swap the tachometer itself and kept the original cluster in and just swap the coding plugs lol there are differences in cluster but I cant remember what can be swapped and what cant be and I dont feel like digging my box out of clusters at the moment
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
Well it can be a few things connection, bad tach, theres actually a ton of info on diagnosing the cluster between here and bimmerforums and e30tech but I almost can bet that one light is out just steal the bulb from your old cluster and change that its on the back of the cluster you just turn it with needle nose pliers but your gas gauge has to be changed it was just easier to swap tachs between the two clusters in my opinion. if your old cluster worked good
Originally posted by JeLani View PostWell theyre different manufacturers, the one thats in is a VDO and the eta one is a Moto. Are you telling me to put my eta plug into the i one? I have another i one lying around too .
Originally posted by alpineE30 View PostWell it can be a few things connection, bad tach, theres actually a ton of info on diagnosing the cluster between here and bimmerforums and e30tech but I almost can bet that one light is out just steal the bulb from your old cluster and change that its on the back of the cluster you just turn it with needle nose pliers but your gas gauge has to be changed it was just easier to swap tachs between the two clusters in my opinion. if your old cluster worked good
The battery light was dead so , you may or may not have seen, but i was bitching alot when i first got on here because my battery wouldnt last a week. 86 eta cluster so it didnt have a resistor for dead lights like later ones and bla bla you probably already knew that. That no longer happens on the new cluster but FYI the tach did not work on the eta one either. The gas worked fine though but you already told me why it doesnt know so i know what to do for that.
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
So ok i will switch plugs and see of that works and when i have time tomorrow i'll take it out and try and donor the eta gas guage to it , suggestions on doing this?
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
Originally posted by alpineE30 View PostLOL dont add another cluster into the mix to much juggling around already
Sorry but i mean to say " I " coding plug sir lol
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
Originally posted by JeLani View PostSorry but i mean to say " I " coding plug sir lol not cluster only two clusters involved haha
1998 e36 328ic/5 -
1967 2002 parts car
1994 318iS junked.
