Spring/Tube of death...intake mani removal help
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    The pressure has more to do with the position of the tube. Once it's in the correct position it's easy to move around.
    If it's stuck on the car I would not cut it with a Dremel because you risk getting metal shavings inside the crankcase. I would try to bend it in the middle a little to make it give way from the angle then cut out the bent middle part.
    Regardless a replacement tube isn't that expensive if the hose replacement idea doesn't work out, though I'm willing back my idea 100%.
    • etxxz
      • Feb 2006
      • 2085
      naw man you're right. lets not cut. i can't bend the tube either and its stuck in place so i'm gonna let it be for today and calm down. ****!! thanks for your help bro
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • RobertK
        • Jun 2005
        • 5864
        Taking a break always helps. If you decide to slightly bend it use a hammer or a mini sledge hammer to dent in one spot of the middle to do it. Don;t get to crazy with it though.
        • MA325is88
          • Mar 2005
          • 580
          I had one once that I couldnt get. I have to back ritalin...I cut it with a smallish craftsman exhaust pipe cutter. When i couldnt get a replacement pipe in time, I bought some heavy duty gates heater hose and put a piece over it and clamped it. Its on the car to this day. AS long as there are no vacuum leaks, its serves its purpose.
          • etxxz
            • Feb 2006
            • 2085
            heh that's exactly what Ritalin_KID suggested, but we didnt want any metal shavings inside the crankcase = slow and painfull engine death. I gotta work today so i guess i wont do any work till mon-tus!
            91 BMW 325i [sold]
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              Did you figure this out yet?
              Yours truly,
              Rich
              you kids get off my lawn.....
              • ldsbeaker
                • Aug 2004
                • 3098
                Not to be a total noob or anything, but is this something that happens every time you take the intake manifold off? I was thinking about painting the manifold, and redoing the gasket while I had it off... Pictures of this in the car would really help, I guess.....
                Slicktop City!
                • RobertK
                  • Jun 2005
                  • 5864
                  You can cut it BUT I would immediately pour some oil down the bottom tube to flush any small shavings and then change the oil.
                  A better method to avoid the shavings is to weaken the tube without cutting all the way through it and then wacking it with a hammer to bend it at the seem. This keeps the shavings on the outside of the tube.
                  • silversleeper
                    • Mar 2005
                    • 2032
                    I yanked down hard on it from the drivers side, and it got shoved into the bottom hole to the point it got stuck in there, so I left it. When I was ready to reinstall the mani, I just pulled up on the tube and all went well.
                    Claus Luthe is my hero.
                    • etxxz
                      • Feb 2006
                      • 2085
                      oh...how i envy you.
                      i was able to it all back together. i notice none of the mid/front gaskets ripped and was able to change the leaky one (6cyl). The car runs like a charm now. BUT i want to take it off to paint the intake mani now.
                      I'm end up cutting the tube in a few houndred miles when i gotta change my oil again
                      u guys kik ass! ty
                      91 BMW 325i [sold]
                      • RobertK
                        • Jun 2005
                        • 5864
                        Hey.. if you're gonna go with my plan.. then what about that Paypal balance bub? ;)
