weird vibration when cruising
  • wme30
    • Nov 2015
    • 61
    Hey R3v,
    Went for a drive yesterday and noticed that the car seems to like shake a bit at any cruising speed, or at low rpms. Its not huge like the cars bucking or anything but it kinda feels like im driving over a road with tiny ripples all over. Spark plugs recently changed, I have red akg motor mounts and tranny mounts. Engine idles perfect without any vibrations and theres no hesitation when accelerating also. Any ideas on what it could be?
  • wme30
    • Nov 2015
    • 61
    Also- ran out of gas a couple weeks ago (bad sending unit), could it be the fuel pump?
    • Kershaw
      • 11822
      Front end suspension, sounds like it.
      Control arms and bushings would be the first I'd replace. Then strut mounts. Then anything else that moves or is rubber.
      AWD > RWD
      • wme30
        • Nov 2015
        • 61
        Thank god I really hope thats it, ive been feeling more vibrations in the steering wheel too. Currently trying to decide what to blow my money on; hr race springs and new rear end bushings, or front end stuff.
        • Das Delfin
          • Sep 2014
          • 2293
          I would start by balancing your wheels because that's the main cause of steering wheel vibration. Then do your tie rods, control arm bushings, strut bearings/upper mounts
          • Maddog
            • Dec 2006
            • 117
            Check your ball joints, too. I had vibrations which worsened during a slight turn of the wheel to the right during highway speeds; it was severe vibrations and new it was not the wheel balance. It was my ball joints connect the control arm to the strut.
            I confirmed by jacking up the front end and held the wheel at the 3-9 position and see if it had any play; you guessed it, it has play and when I did it again watching the ball joint, it confirmed my diagnosis.
            Changed both control arms and tie rods; not worth taking chance with a failed ball joint. Being an OG, I had RyanGMW replace them; in at 8 and out by 11.
            • Streichholzschächtelchen
              • Jan 2009
              • 1670
              It could be your shock giving up the fight. I have new tie rods control arms and cabs, when i take a fast right hander my wheel hops and shit, causing understeer unless I lift a little. Fosho is the inside wheel not knowing what to do lol. Sketchy
              Jah bless! :pimp:
              • stillkotd
                • May 2011
                • 127
                Our cars are super sensitive to wheel balance. Cheap tires or rims that aren't hubcentric can cause lots of bad vibes.
                1989 325i m50b25tu swap
                1989 325i (sold)
