alternator belt keeps flipping?!?!?!
  • King Luis
    • Sep 2004
    • 737
    so i replaced my alternator belt and power steer belt after 1 snapped and the other was pretty much toast.
    the power steering belt installed fine and isn't giving me problems.
    but the alternator belt for some weird reason will flip over (with teeth side up) and stay like that. the tension is good and i've replaced the first replacement that has done the same thing.
    what the hell is going on???
  • Tangent
    • Mar 2004
    • 476
    Is it possible that the belt is on the wrong part of the crank pulley? ie it's supposed to be in front of the other belt but it's installed behind it or vice-versa?
      • 34839
      something is probably bent or out of alignment.
      • King Luis
        • Sep 2004
        • 737
        its in the right pulleys and everything looks straight and undamaged.
        i'm taking it to my mechanic this week.
        • dirty30
          • 3014
          Check the bushings on the alternator, they wear out and cause the alternator to sit at a funny angle making the belt fray and eventually fly off. Happens more with the s14 though ...
          -R
          • King Luis
            • Sep 2004
            • 737
            hmmm...good point.
            • arsevader
              • May 2005
              • 1025
              -R
              Plus the later cars don't have rubber bushings. The bushing is integral with the alternator case.
              Are you absolutely sure a) It's the right sized belt and b) it's on the right pulley?
              I know you answered b) but you need to be sure.
