Fuel, ABS, Clutch and more problem..325i 87' m20b25
  • FaragMan
    • Feb 2016
    • 39
    Hello everyone,
    I recently (7 month...) bought my e30 and drive on her only a 2 hour :(
    I have some problem:
    1. During drive hard (maybe when turn right?) suddenly I lost the gas pedal. And immediately felt a very strong smell of fresh fuel from the engine.
    *note: on my e30 has two fuel tanks, one regular under the vehicle, and the other in the trunk. (original optional BMW)
    2. ABS is not working, what is the problem usually?
    3. If my vehicle creates 12/1986, do I need to use electrical diagram of 86 or 87?
    4. what about ZDDP additive? YES\NO? With Castrol GTX motor oil 20w50 or is it better the Liqui Moly 20w50? or maybe 15W40 Mobil 1 pegasus (full syn)? (I live in HOT country).
    5. I have a clutch pedal problem, is too low in the 0 place,
    I need to press the clutch pedal into the floor mat to transfer a gear, and the pressing is very hard..
    (changed the the clutch master cylinder for new) (didnt yet changed the bottom pump) (drained air).
    6. what spark plug is the best?
    7. my car is Auto to manual conversion. But I still have this plug and switch,
    I can not rotate the switch when the engine is turned on,
    If I turn on the switch when the engine is turned off, the switch goes back to a specific point when I turn on the engine.
    In short: how to eliminate all of this? I tried to disconnect the switch and the engine does not work well \ starter does not stop working ..
    8. Reverse light lights up only when I move the gear shift to the left,
    But when I put the reverse gear light turns off.
    Sorry about my english.
    Thanks in advnace for who read all this, can help me...
    Eden
  • TobyB
    • 5280
    I'll start:
    3: 1987, BMW did it by model year.
    4: I would. It doesn't hurt, and GTX doesn't have enough zddp.
    6: I swear by NGK
    hth
    t
    • FaragMan
      • Feb 2016
      • 39
      Originally posted by TobyB
      I'll start:
      3: 1987, BMW did it by model year. thanks!
      4: I would. It doesn't hurt, and GTX doesn't have enough zddp. So Liqui moly 20W50 + zddp is Ok?
      6: I swear by NGK Which model?
      hth
      t
      Thanks for comment !! :)
      • FaragMan
        • Feb 2016
        • 39
        More please?
        • FaragMan
          • Feb 2016
          • 39
          What I need to do run with m20 with zf320 gear?
