will 19lb mustang injectors screw up my OBC
  • ptownTSI
    • Jun 2005
    • 1265
    i'd like to keep it accurate if possible but from what guys are telling me teh 19lb mustang injectors really do alot of good things for these old bmw's.
    • 34844
    yes
    • kailuaboy
      • 54
      Are they any wiring mods that you have to do??
      • ptownTSI
        • Jun 2005
        • 1265
        nando you did mention that your gas mileage went up a bit with the injectors so if anything the OBC will be reading low??
          • 34844
          no, it still reads high. we are talking about like a 1-2% increase, which was probably just from switching to cleaner injectors. but the MPG will be off by 25-30% because of the reduced duty cycle; the computer still thinks you have stock injectors but it doesn't have to turn them on as often or for as long so it thinks you are getting better MPG than you really are.
          as far as I know there is no way to fix it
          • ldsbeaker
            • Aug 2004
            • 3098
            Besides junking the econo meter and wiring in the ///M3 oil temp gauge.. hmmm???
            Slicktop City!
            • RobertK
              Kicked cancer's ASS.
              • Jun 2005
              • 5864
              Be sure you understand that the 19lb injector mod is only good for the M20B25 in the 325i and 325is.
              If you have a M20b27 "eta" engine found in the regular 325, 325e or 325es then 19lb injectors will fry your DME from what I've been told due to the difference in impedence.
              • n3nyongmini
                • Jun 2006
                • 593
                Do the 19# give one any gain, really, on a stock (mine) setup?
                HE>i
                89 335i m30 power, 4hp22 delivery
                • vivalegreg
                  • Apr 2006
                  • 1313
                  bump bump
                  e30s r kool
                  • cahomey
                    • Mar 2004
                    • 1201
                    Slightly, the more mods the more power difference.
                    Better mileage? Probably a small amout.
                    Just gives you a more reliable, newer, 4 pintle injector.
                    Before you install them, take them to get cleaned. It's worth it.
                    "It's like a koala bear crapped a rainbow in my brain."
                    R.I.P. Harry Goz aka. Captain Murphy
                    "My ride, My ride, she don't beg, steal, cheat, or lie,
                    My ride, My ride, and our relationship is classified."
