bolts instead of studs?
  • NC325iC
    • Mar 2004
    • 6565
    ok just wondering, in the case of the valve cover are there any benefits to keeping the studs? it just seems it would be just as easy to just use bolts.
  • Adrian_Visser
    • Jun 2006
    • 2823
    i believe the studs are used so that its easier to line it up while your putting it on.
    you could i suppose change it to bolts if u like, maybe keep a couple studs thought to help line it up while it goes on
    '89 Alpine S52 with goodies
      • 34844
      actually, studs are used so you don't strip out the threads in your head from taking them off and putting them back on a million times when you are adjusting your valves, changing gaskets, etc. etc.
      • Adrian_Visser
        • Jun 2006
        • 2823
        ahh that makes more sense
        • NC325iC
          • Mar 2004
          • 6565
          that does make sense, good job nando
          • 2002maniac
            • 4260
            The M42 has bolts. 3 of mine are stripped :(
            • AdamF 88iS
              • 2051
              Indeed.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
