Car stalling...........
    Since if had my 89 325i auto my car has had a problem stalling. no matter what speed it will just cut out. when it stalled and i gave it gas and or put it in neutral it would sometimes come back. i also noticed that the check engine light would come one sometimes but would never stay on.
    well last night my car stalled bigtime and it took like 2 mins to get it started. and my check engine light is stuck on now. i did the bentley thing and it doesnt even blick, it just stays on. so would my Mass Airflow Sensor be bad?
    thanks
    NEED SOME VINYL STICKERS???
    anyone?
      Without knowing more, I would say that or you arent getting fuel... I have had two fuel pumps go out and they did so intermittently, hence stalling. Occasional no starts, however until replacement, a good whap on the cover over the fuel pump got it working again. My best guess as those are my experiences with stalling.
        brand new bosch is in there now....
          what bentely thing did you do?
          Yours truly,
          Rich
          you kids get off my lawn.....
            well i talked to a european mechanic. he said that because the car was just cutting out (RPM just die) that it isnt fuel related. told me to check the speed and reference sensors.
              I think we are talking about different symptoms with the same words then. I have had two act that way and it was fuel related both times... Good luck and let us know when you find out.
                fuel filter, I used to have this issue
                Count down to 1,000,000 miles: 490,649 to go
                  new fuel filter, im ordering new wires, plugs, coil, distrib. cap, rotor, impulse sensor and new fuel pressure reg. then ill go from there!
