hesitation worse when A/C on
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals. -
All of those plugs look like they are overheating, assuming you have the correct spark plugs I'd suspect a weak fuel mixture. Maybe marginal fuel pressure or bad/blocked injectors.
An air leak could cause similar plug overheating but you would have a ton of other symptoms so I doubt this is the case here.
It also looks like there are deposits on the plugs, maybe worn valve guides or seals allowing enough oil to foul the plugs, once contaminants bake onto the plugs they can't self clean and will overheat.
A fuel pressure and compression test will eliminate some of the possibles. Though a bad (or wrongly set) TPS, worn AFM carbon track or poor C191 connections are other candidates.Comment
Thanks for the responses! Awesome info. Plugs are correct. Cap and rotor are new. I will start with the compression and fuel pressure, and then report back.
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
