Rough Idle
  • Badabing86
    • Mar 2016
    • 44
    Rough Idle
    I recently did some gasket replacement on my 325 (valve cover, intake/exhaust, oil pan) and after placing everything back together I noticed I have a rough idle, my cars super lopey, and when shifting gears or rolling to a stop my car will die. But turns right back on. Anyone know what sort of issue this is? Specific Vacum hose to look for that would be causing an issue?
  • Kershaw
    • 11822
    It definitely sounds like you forgot to attach some hose.
    If you zip tied your crank case vent tube spring down, did you remember to cut and remove the zip tie? You need to double check everything in your engine bay.
    AWD > RWD
    • Badabing86
      • Mar 2016
      • 44
      The crank case vent tube was compressed with a pry bar then the intake went over and I slid the pry out and it snapped into place. So that is fully extended . The only one I questions about is the two hoses that connect to the TB.
      [IMG][/IMG]
      • dnguyen1963
        • Nov 2011
        • 2651
        Do a smoke test. I bet that you are going to find smoke coming out in a lot of places.
        • Badabing86
          • Mar 2016
          • 44
          Hows that done by, just running the car and seeing what smokes?
          • Kershaw
            • 11822
            I bought a fog machine off amazon. I haven't actually used it yet though.
            AWD > RWD
