Coolant cap recall
  • 1843lamp
    • Sep 2015
    • 276
    Coolant cap recall
    I have looked but I can not seem to find out what pressure rating the early e30 cars had 83 -87 etc .the coolant tank cap ,I know there was a recall that involved changing the coolant cap to 1.4 bar ,does anyone know the original cap rating?
  • jeffnhiscars
    • Jun 2011
    • 6011
    If it was recalled why would you want to know
    Alice the Time Capsule
    • 1843lamp
      • Sep 2015
      • 276
      I am somewhat hesitant to say that my car is in such original condition,including most small detail items ,original spare tire,flashlight etc...even the original marked water hoses ,I am the first person to actually change many original things ,water pump ,idle pulley ,timing belt..even the rear brake pads ( textar)may be the originals ,although I do not know if it was common factory practice to use different pads in the front (pagid).so,I have been locating all of the small items it came with from the factory just to have them ,even including the original valve stem caps..
      • noid
        • 1536
        The recall mainly addressed the pressure problem with a bypass valve located just before the heater core, they did however also replace the coolant cap as part of the recall.
        The new part number 17114379047 is 1.2bar, the old part numbers where:
        17111152060 which was 1.0 bar.
        17111152061 was used from 1981 until 1984 which was 1.2 bar.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • 1843lamp
          • Sep 2015
          • 276
          Great information ,thank you ,I now know what to look for .
