Solid Brake Guides
  • elemental
    • Jan 2004
    • 112
    Solid Brake Guides
    http://www.bimmerworld.com/html/solid-brake-guides.htm
    My front right caliper has the shakes, under light braking but if i get into them harder they stop shaking any one think this may be the prolbrem>?
    Matt
    • 34839
    it could be several things. warped rotors, worn out ball joints or control arm bushings. I'm not sure of those guides would contribute to shaking or not (all my brakes/calipers are new).
    • elemental
      • Jan 2004
      • 112
      Recently replaced items include, Mintex Pads, ATE rotors new wheel bearings new control arm bushings new outer tie rods. when you spin the rotors there is a deveation of the distance between the rotor and brake pads,. allso it seams that the carrier is slopy on the caliper, any ideas?
      Thanks Matt
