Check light
  • Nick_e30
    • Mar 2016
    • 173
    Check light
    My check panel doesn't work and I have the blinking check light on my dash. All my fluids and lights are fine but it still blinks. Any one have any idea what it could be ?
  • CarsonE30
    • Jun 2015
    • 2124
    Could be anything. Hope that helps
    C6Z
    S2K
    VeloN
      • 34827
      does your check panel not work at all? you have to be more clear.
      Sometimes the brake light switch fails and causes the check light to stay on.
      • Nick_e30
        • Mar 2016
        • 173
        The button works for me to reset it but the lights to indicate the problem doesn't work
        • 101
          • Jul 2011
          • 764
          That's going to be a hard one to diagnose without the individual LED's in the check panel working.
          You might be able to narrow it a bit if the issue starts only when you turn the lights on (which would be triggering the license plate light or tail light warning). Otherwise it could be any of the other items.
          Make sure the wiring at the oil level, coolant level and washer fluid level sensors is clean and tight.
          If the above doesn't solve your problem, the next step would be to try to swap in a known good check panel. Do you have access to one to swap in?
          101
          The E30 collection:
          1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
          1987 325is - Delphin / Black Sport (son #3's)
          1987 325i Convertible - Triple Black
          1989 325iX Coupe - Diamondschwarz / Black Comfort
          1990 325iX Coupe - Sterling Silver / Grey Sport
          1981 Fiat 124 Spider 2000 - Green / Tan
          1998 Volvo V70 GLT - White / Tan
          1998 Volvo S70 T5 manual - White / Taupe
          2001 Ford Windstar - Silver / Grey (parts hauler)
          2006 Lexus GX470 - White / Tan (tow rig)
