Hey guys. Thank you in advance for any help you can offer. I recently picked up a beautiful 87 325e. It runs absolutely great as my daily driver. ...but every morning its a good crankin before we're off to work. I've read quite a bit about a check valve in the fuel pump going bad, and have a heard a whine in the back right.. probably 2 or 3 times. Very inconsistent. I'm assuming fuel is seeping back down into the tank overnight and the long cranking is just my fuel pump priming the line again. If the car is relatively warm (3-4 hours since last drive) it starts right up, no hesitation, every time.
The car was well maintained and is in great condition. I have replaced some worn looking fuel lines, spark plugs, fuel filter.. might be forgetting something here. Recently I tried a check valve I purchased from Summit racing in my fuel line right above the fuel pump in the gas tank. The car would start with the check valve installed but would quickly starve out? Removed immediately didn't test overnight.
Anyways my questions here are how many fuel pumps are in this car? Which one do you think I have a problem with? Any way to test? I'd like to replace whichever one is faulty. Your thoughts?
