Play in sunroof/sunroof loose
  • aaaaah
    • Nov 2013
    • 34
    Hey all,
    Been searching for a while now, using all the descriptions I can think of but not really coming up with anything. I have a 91 325i coupe and the sunroof is, for lack of a better word, loose. By that I mean if you push on the sunroof, hit a bump, close a door or it's just really windy, the back side of the sunroof will lift up. It isn't held tightly closed.
    Any ideas before I try and tear into it?
    Thanks
  • roguetoaster
    Biggus Tippus
    • 7830
    Is it working? If not I'd suspect that the end of the cable, which is plastic, has broken.
    • aaaaah
      • Nov 2013
      • 34
      Still works in both directions.
      • DirtyTh3rty
        • May 2015
        • 101
        Mine also will jump the tiniest bit in the back when i close the door quick and mine functions perfectly too. Never noticed it any other time though and its never leaked so i never really thought of it. guess it isnt normal then huh? hahah
        88' BMW 325is - Daily
        • Kershaw
          • 11822
          Mine does that too. The tabs are rusted off. I think it's only held on by hopes and dreams at this point.
          AWD > RWD
          • aaaaah
            • Nov 2013
            • 34
            Wouldn't bother me so much except it leaks a small amount when it does it. Doesn't leak otherwise.
            Have to check the drains too to make sure it's all getting away. Haven't bothered because the small leak coincides when I hit a bump haha.
