Okay I'm putting an A/C belt on my M20 using stock compressor etc. I have a 13x825 but I can't for the life of me get the belt over both the crank pulley and the A/C pulley. I had the same problem with the water pump/alt belt and I ended up removing the water pump pulley, inserting the belt in the pulley, and bolting the pulley back on. Crazy.
I don't know if I can do that with the A/C pulley and I'm not going to take the crank pulley off because then I'll have to mess with the water pump puley again. Can I just loosen the 13mm on the front of the A/C compressor? and put the pulley back on with the belt around it? I'm worried about damaging the compressor or not having enough room to fit the pulley on with the belt attached
Any suggestions for a different belt size? I went to autozone and the next size up wasn't metric and is a bit too loose with the tensioner fully extended. I put on new tensioners etc today.
This is the last step before I can charge my A/C system!
