Firm pedal, poor braking
  • 1point8litre
    • Feb 2014
    • 15
    Hey guys, I replaced my master cylinder and now my brakes are very firm with little travel. But they're not biting at all. If I stand on the brakes, they travel as far as they do and then the car eventually stops. I've been reading about a bad ABS module or bad booster. Any thoughts?
  • roguetoaster
    Biggus Tippus
    • 7830
    Did fluid come out of all four bleeders at a similar rate when you bled the system?
    Did you bench bleed the master?
    • Das Delfin
      • Sep 2014
      • 2293
      Sounds like a bad booster
      • RobDog
        • Aug 2012
        • 188
        To test the brake booster do the following. 1)With the engine off, pump the brake a few times until the pedal gets stiff, then continue holding the pressure on the brake pedal. 2) While holding pressure on what should now be a stiff brake pedal, start the engine. 3) If your booster is good within in seconds of starting the engine the brake pedal should drop about a half inch and should feel softer.
        • bangn
          • Sep 2011
          • 760
          certainly sounds like a booster issue. Check the pipe that runs to the booster hasn't disconnected somewhere.
          Boris - 89 E30 325i
          84- E30 323i
          • tomstin
            • Mar 2015
            • 570
            Let me jump on the failed booster train. Had this happen a few years back on another call while driving. Both feet on the brake and pulling up on the steering wheel to put everything I had on that brake pedal and the car barely slowed.
            2004 525i Manual - 1985 325E Coupe Manual
            • 1point8litre
              • Feb 2014
              • 15
              Thanks guys! Any opinions on the reman'd A1 Cardone? I'd like to grab an ATE, but I don't want to spend $300+.
              • 1point8litre
                • Feb 2014
                • 15
                What would indicate that it's working, but not efficiently?
