How do you get the heater box out? The dash is removed, the heater core lines and the A/C lines are disconnected, the bolt at the center console is removed and the 4 nuts holding the heater box at the blower motor area/cowl are removed but still it's not coming off. Any help on how to remove it without damaging it will be appreciated, I don't want to work around without removing it. Thanks.
Heater Box removal, anyone?
.....sounds like you got it all.........there is a glue on foam type gaskets that surrounds the area where the blower motor pokes through shell.....there is also a rubber plug that goes through the firewall (surrounds the rad inlet/ outlet tubing)................you have to pull it out from the bottomHow do you get the heater box out? The dash is removed, the heater core lines and the A/C lines are disconnected, the bolt at the center console is removed and the 4 nuts holding the heater box at the blower motor area/cowl are removed but still it's not coming off. Any help on how to remove it without damaging it will be appreciated, I don't want to work around without removing it. Thanks.Last edited by 411; 06-11-2016, 08:54 AM.sigpic -
There's drains and floor air ducts that may have to be removed too if they are there. It should be ready to come out though."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER
89 M3 - ALPINEWEISS II
91 M TECH CABRIO 2.7L TURBO - MACAOBLAUComment
