Need part # for splash guard (undertray)
  • mike.bmw
    • Dec 2015
    • 1758
    I've found the part numbers for the left and right air ducts on realoem.com. I've spent hours searching for the part number for center section of the spash guard / undertray and I'm coming up with nothing.
    It's the large plastic piece that goes between the front frame rails in the picture below:
    I'm also looking for the part numbers for the fasteners that hold it all together.
    I realize I don't *need* to run one, but I want to.
    Thanks for any input!
  • PKile
    • Apr 2016
    • 184
    I just bought one of those...the part number is 51 71 1 965 899. The part is on RealOEM under Trim/Heat Insulation and is called Engine Screening. The thing is held in place by a combination of plastic body nuts (the same type used on the side molding) Tinnerman nuts, and self tapping coarse thread pointed screws with integral washers (lots of Japanese cars use them on their undertrays...go to Pick N Pull to find hundreds of them).
    • mike.bmw
      • Dec 2015
      • 1758
      Awesome! Thanks so much! I can't tell you how much seaching on realoem and google I've done and come up with nothing... splash guard, undertray, splash tray, belly pan, skid plate, etc....
      Now that I'm looking at it a little closer, there appears to be another piece that goes between the large 'engine screening' an the metal front valence. I don't see that in the parts diagrams either. See photo:
      • PKile
        • Apr 2016
        • 184
        I don't believe there is another piece between the two...the front edge of the engine screening clips into the cross brace below the radiator...which is part of the body and not shown in your photo.
        • mike.bmw
          • Dec 2015
          • 1758
          Ah, that would make sense. Thanks again!
          • jeffnhiscars
            • Jun 2011
            • 6010
            ignore everything I erased :)
            Alice the Time Capsule
