Driveshaft center bearing breaking?
  • Turbo E30
    • Jun 2016
    • 13
    I have a 1985 325e with a stroker engine and it is boosted. But the center driveshaft bearing keeps breaking no matter how much i replace the bearing. Should i just get a custom one piece driveshaft?
  • PKile
    • Apr 2016
    • 184
    Have you checked your u-joints? Bad ones can stress the CSB.
    • roguetoaster
      Biggus Tippus
      • 7830
      Are you getting a quality part? Are you preloading the bearing? Is the driveshaft no longer balanced?
      • TobyB
        • 5297
        The bearing shouldn't be taking the worst of the hit-
        to the above, I'd add alignment.
        Unless you are 'drifting', at which point you might just be moving things
        around so much that the CSB is the weak link.
        And yes, several have done one- piece- look in the trans and driveline subsection.
        It's a custom thingy.
        t
        • Turbo E30
          • Jun 2016
          • 13
          t
          Thx. I am a little new to this, is there anything that is easy to look for to tell if the alignment is off.
