New 91 318is Owner - Need help finding a list of repairs/upgrades
  • mariosg37
    • Oct 2015
    • 2
    Howdy,
    Does anyone have a comprehensive post with maintenance items/upgrades that they have done to their 318is? I remember seeing a website from a guy in Ireland that had laid out all the things you need to do with a car with 160K miles on it. It included upgrades like steering rack, air conditioning suspension and maintenance items like oil pump, etc. I am looking to start workin on the car and need some help.
  • Shangsta
    • 1485
    jack your car up look for any leaks, worn rubber lines, suspension bits ect, if something is not working like it should then make a note. Then fix everything that needs to be fix. Seems like a simple enough method to me
    :shock:
    • c0rbin9
      • Dec 2015
      • 609
      I just got a 318is with unknown maintenance history and here is my list, which is by no means comprehensive:
      -Oil change
      -Fuel filter change
      -Air filter change
      -Coolant change
      -Brake fluid flush + bleed
      -ICV cleaned
      -valve cover gasket/inspect timing gears and chain tensioner guides
      -Inspect and replace vacuum hoses
      -Make sure temperature gauge reads accurately
      -Timing chain tensioner piston thing
      Also did non-engine related stuff like grease all hinges/strikers, rebuilt the window switches with electrical contact cleaner, cleared drain channels, replaced leaky gaskets, and more.
      1991 318is Brillantrot daily driver (slow restoration)
      • jrobie79
        • Mar 2006
        • 2526
        1991 318i ---- 308K - retired
