fuel filter mount question
  • PKile
    • Apr 2016
    • 184
    Here is a photo of the fuel filter mount bracket out of my 92 325iC. What is the plastic arm for?
  • Seawolf
    • Feb 2015
    • 270
    It's a steady for the fuel filter canister. The rim of the fuel filter fits into the notch in that arm to stop it wagging around and stressing the fuel lines when you hit potholes
    • jeffnhiscars
      • Jun 2011
      • 6011
      I'm not sure if they changed it in later years but my 87 has 3 rubber mounts holding the fuel,filter frame t the chassis. They are very similar to the ones holdi g the air filter box to the inner fender...only way more expensive
      Alice the Time Capsule
      • PKile
        • Apr 2016
        • 184
        Cool...thanks guys. I figured it was a steady bracket because I test fit the new filter and the lip fit perfectly into the notch.
