Noob question: Evaporator Box Seal
  • c0rbin9
    • Dec 2015
    • 609
    I've determined that the source of my interior leak is the A/C evaporator, specifically the seal around the plastic box. I've taken out a lot of the interior and now have reasonably good access to the box, but the top half can't be completely removed without disconnecting the lines, which are routed through a cutout in the box.
    So my question is what is the least painful way to seal this box up? I'm guessing I have to remove the lines in order to properly put some gasket maker on the box.
    Looking for a little reassurance from somebody who has experience here. I've considered laying down some gasket maker on it with the halves still in place but unscrewed, but it just doesn't seem right.
    Thanks for any help.
    1991 318is Brillantrot daily driver (slow restoration)
  • jeffnhiscars
    • Jun 2011
    • 6010
    If I understand correctly you are talking about the seal between the dash vents and the HVAC unit itself. This one requires removing the dash.
    Is this an air leak or is it something else ?
    Alice the Time Capsule
    • c0rbin9
      • Dec 2015
      • 609
      No, water leak from the evaporator.
      I'm talking about the small plastic box/housing that covers the evaporator. It is on the left side of the passenger footwell. There are drain tubes connected to it - in my case there was no seal between the two halves of the box, causing condensed water from the evaporator to leak onto the floor instead of exiting through the drain tubes. I'll take a pic when I get home.
      • spike68
        • Apr 2009
        • 1185
        was it just dangling there when you found it? I should be screwed into the rest of the box.
        But to help you with a solution just put a bead of RTV or silicone around it and press it back into place. I resoted to that solution because when I removed mine to replace the expansion valve I was able to get two of the four screws undone, but was unable to put them back. I used the RTV to ensure it sealed and replace the screws I couldnt get back. Not the best way to do it, but I have not had any issues.
        I don't even own this car anymore, but I'm too lazy to change the picture.
        • c0rbin9
          • Dec 2015
          • 609
          Thanks, that's what I thought. Mine wasn't dangling, but it was secured by only 2 screws like somebody had already tried to repair it.
          I'll go with the easy solution for now.
          • c0rbin9
            • Dec 2015
            • 609
            "Easy solution" my ass... so the box doesn't seem to fit over the evaporator. I can only attach one side or the other side. Is it possible that the car has a larger (r134a perhaps?) evaporator with the smaller size box? Nothing would surprise me on this car.
            EDIT: Texted previous owner... was converted three years ago, probably doesn't fit now. Am going to cut box with dremel as soon as someone tells me I can remove these lines without issue.
            • c0rbin9
              • Dec 2015
              • 609
              Can I remove the lines as shown here:
              ...from the evap valve without doing anything special to depressurize the system? Would make this a lot easier.
              • c0rbin9
                • Dec 2015
                • 609
                Well that was an interesting 4 hours. Got everything back together and sealed except for the lines. Can't thread the damn things on. Will try again tomorrow.
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  If you are talking about threading those 2 ac lines back on, do the larger one first. Of course replace the o rings and don't torque the hell out of them or they will leak. Let the oring do its job. You know you need a new dryer and proper VAC/charge and if you have the time I'd actually remove those lines completely and have them rebuilt with r134 barrier hose. I just did this (finally) after living with leaking hoses for years and am getting low 40s at the vents with 95 outside and middling humidity.
                  Ps...r134 upgrades don't physically change anything except the fitting adapters (that's usually how you tell) and possibly a compressor change.
                  • c0rbin9
                    • Dec 2015
                    • 609
                    How can I tell whether the car has been r134a converted? It is not obvious to me. There are no stickers. I need to know what to recharge the system with.
                    Would the style of the drier tell me? It is the one with only 1 switch - the other plug that would have attached appears to be jumpered. Which means it is r134a, right? I'd rather not put the wrong stuff in.
                    EDIT: I'm thinking the car is still R12. This car is a money pit.
                    • jeffnhiscars
                      • Jun 2011
                      • 6010
                      You quoted the PO as saying the car was converted 3 years ago.
                      The rule of thumb though is if the gauge fittings have the r134a adapters. Driers I believe look the same. Check the expansion valve markings although you can convert using the original valve and green (HBNR) o rings would also suggest a conversion
                      • c0rbin9
                        • Dec 2015
                        • 609
                        I misspoke in my previous post - he said the car had the A/C system serviced, dunno if it was converted.
                        I seem to have cross threaded the big line trying to get it back on. I thought this whole job was going to take 30 minutes... lol.
                        Car has green o-rings, original R12 gauge fittings, and expansion valve w/ no stickers or anything. So sounds like R12, just with green o rings?
                        • jeffnhiscars
                          • Jun 2011
                          • 6010
                          Someone could easily have used the green orings serving an r12 system. The gauge fittings are a pretty compelling case for an unconverted system. r12 uses mineral oil and r134 uses pag although either system can work with ester so I really don't know how you tell them apart without something that leaps out and bites you in the ass.
                          You can try swinging by an ac shop and get their opinion but again, I suspect th gauge fittings being r12 will get you the same reply.
                          At this stage, I'd give it a VERY thorough flush to get whatever oil is in there out, add some PAG (I think 250cc) then see if you can get the system to hold a deep VAC. If you're that lucky, throw in some r134 which I get for $4/can ($48/case shipped from Amazon) and cross your fingers.
                          • c0rbin9
                            • Dec 2015
                            • 609
                            Thank you for all the advice, I'll take a look at this and update the thread next time I get the chance.
                            • c0rbin9
                              • Dec 2015
                              • 609
                              I took some pics and hopefully can get some feedback on what I've got before ordering parts. Here's what's going on:
                              Here you can see the pressure switch is disconnected from the drier and jumpered with a yellow wire. Why would the switch have to be bypassed like that?
                              Also here are the fittings:
