Wtf has the PO done to my headlamp switch loom
  • bangn
    • Sep 2011
    • 760
    putting my harness back into the car since doing the resto and found this. It has me confused as hell.
    This car has a history of workshops "bridging connectors" to keep warning lights off.. including brake wear sensors ffs.
    so hes bridged two br/wh wires on the headlamp switch loom at the plug. I cant get my head around why. Hopefully someone can shed some light
    obviously the car is still a bit from being completed so I cant simply just unplug it and see what happens.
    edit: I remember years ago the dimmer switch never worked..
    The dash cluster was quite dim illuminated and I found the circuit board was pretty crispy in places (electrical burns)
    SO I replaced the cluster and the dimmer still didnt work but I had my lights back.
    Thinking now maybe the headlamp switch had a fault, the guys bridged the dimmer and cooked the cluster.
    just a guess
    Boris - 89 E30 325i
    84- E30 323i
  • PKile
    • Apr 2016
    • 184
    The check control system has warning lights for burned out headlamps annd taillamps...this may be another attempt to defeat those lights.
    • AndrewBird
      The Mad Scientist
      • 11898
      I'd return it to stock and not look back. Who knows why it's there, but if it didn't come from the factory, then it isn't needed.
