windshield washer pump
  • ziazhp
    • Nov 2015
    • 191
    I've tried searching for a solution but can't seem to find one. I just replaced my washer pump on my iX. The old one worked but was leaking as it was old. I put the new one in and nothing, I can't hear it engaging. Fuses are fine. Any ideas?
    '89 325ix
    '88 M6 Royal Blue
    '13 128i "M-Sport"
    '04 ZHP Mystic Blue-SOLD
    '02 E46 330xi-SOLD
    '89 325i Laachssilber metallic-SOLD
    '89 325i Bronzit-SOLD
  • agent
    Vice Grand Pubaa
    • 7960
    The FAQ/DIY section is for staff-approved instructional posts only. Please do not ask questions there. If you don't know where to ask your question, post it in General Technical and we'll move it to the appropriate subforum if necessary. Thanks in advance.
    Originally posted by kronus
    • cirrusblue
      • Oct 2014
      • 433
      you gotta check the voltage with a multimeter and figure out if you're getting juice to the pump or not. Sometimes the wires get old aroudn there and you can have a continuity issue. If you cant' get juice the pump won't run. if you are then your new pump is bad. If it's powering on, but no fluid you can have a hose issue.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5604
        Check for juice at the plug. Maybe a wire got yanked out of the connector while you were swapping out the old one, or just plug the old one back in and see if that one works.
