Having a little trouble...
  • c0rbin9
    • Dec 2015
    • 609
    Hey guys, I'm having a little trouble here and would appreciate some assistance.
    I'm trying to rebuild my reverse light wiring but can't seem to get started. Any suggestions? I can't find these connectors for sale anywhere, nor have I been able to get the pins out of the connectors to rebuild. Any help?
    Here's a pic of the wiring:
    1991 318is Brillantrot daily driver (slow restoration)
  • M_3_X
    • Jul 2016
    • 162
    I would buy a new harness, but that's just me. I'm sure you'll get the help you need here!
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    ___________________
    River City Bimmers BMW CCA
    2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
    2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
    1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
    • c0rbin9
      • Dec 2015
      • 609
      Are you talking about the entire wiring harness? I'm sure it needs to be done, but don't have time for that.
      Would also prefer to build my own wiring as the factory wiring seems inadequate for this application. They used regular unstranded wire with simple insulation even though it is a high temperature area.
      • PKile
        • Apr 2016
        • 184
        The reverse light pigtail is separate from the harness and is not that expensive from the dealer...around 40 bucks. I bought one a couple months ago.
        • uturn
          • Dec 2010
          • 1004
          Concours? Then get the dealer stuff. Just wires inside a loom and fancy heat shrink connectors would work just fine. Used wiring from the junkyard or a part out would be my route, but that's just me.
          • c0rbin9
            • Dec 2015
            • 609
            Can somebody point me in the direction of where to buy the pins/connectors?
            I don't even know the size as I can't find them on RealOEM.
            • uturn
              • Dec 2010
              • 1004
              Here's the part number for the whole shebang!
              23141220263
              Ecs is selling it for ~$33
