Stomp test
  • 1843lamp
    • Sep 2015
    • 276
    Stomp test
    I have an 87 ES that was made in 5/86 and I know the stomp test will not work. With my 027 DME,my question is these early cars do not have a check engine light on the dash only a check panel light ,if I replace my computer with a later version do I have a light that will blink or do I need do do something more to get the test to work?
  • TobyB
    • 5198
    If you have a hole for it, you don't have the lamp itself, and you "probably" don't
    have the wiring. But then again, it might...
    My 2-87 DID have the wiring- I put in a 9-90 engine, engine harness, DME and dash,
    and after rewiring c101 to not smoke, it all worked, including the 'check' light.
    will help you search for the wires.
    fwiw.
    t
    • 1843lamp
      • Sep 2015
      • 276
      Thank you very much for your reply.what you said was what I was thinking ,I think my car is much too early to have the wiring and bulb,I will just have to keep troubleshooting the old fashioned way.
