swapping electric sunroof to crank?
  • haaken675
    • Sep 2016
    • 601
    Like the title says, can it be done? If so does anyone know what parts i would need? My '87's electric roof only partially works. You have to help it along at the moment, and i can't seem to get it fully working either. I would much prefer to simply swap in the crank parts if possible. i had that on my first e30 and I loved it.
    Thanks
  • SecludedPlayer2
    • Mar 2016
    • 58
    If I'm not mistaken it can be done. The electric motor that opens and closes the sunroof essentially does the same thing as the crank. It'll be a huge pain to change over. It would probably be easier to fix the electric sunroof. I might have parts depending on what you need.
      • 34847
      also the crank sunroof handles suck. They always break.
      if your motor or switch isn't bad then it needs adjustment most likely. Even if you switch to a crank sunroof, it would still need that. if it's just a motor or switch, that's an easy fix. the motors rarely go bad so I'd start with the switch.
