Car Dies at Light
  • Est817
    • Feb 2016
    • 19
    Car Dies at Light
    I got an 86' 325es back in February. Since I drove it I discovered what all the hype was about. It's had a lot of work done from:
    885 head, wiring harness, gasket kit
    Rebuild fuel injectors
    270 regrind cam
    ect...
    It recently died on me while waiting at the light, and wouldn't restart. I noticed after about 30min, it restarted and drove fine for about 15/20 min and then the problem would occur again.
    After doing some research I came to a few conclusions.
    1.My main fuel pump relays
    2. Distributor rotor + cap
    If i'm overlooking anything, please let me know. Any other suggestions are welcomed.
    In my car, [I'm a winner and winners... we don't listen to words like "no" or "don't" or "stop!"]
  • 2mAn
    Señior Mod
    • 20689
    you suck.
    Will the car idle at all?
    If it starts then dies, can you r3v it and will it fight you or will it smooth out?
    Can you do a burnout?
    Do you know how to post pics?
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • Est817
      • Feb 2016
      • 19
      Originally posted by 2mAn
      you suck.
      Car struggles a bit when idling.
      When I rev it, it does fight.
      [IMG][/IMG]
      • ELVA164
        • 4861
        I would suggest not stopping at any lights until the issue is resolved.
        Do you know if/how the ECU is tuned for the different head and cam? Rebuilt OEM injectors or something else? Is it a "soft" or a "hard" miss? Soft meaning the car loses a bit of power, but still runs somewhat, and hard meaning a total loss of power, even momentarily.
        • 2mAn
          Señior Mod
          • 20689
          I helped him with the 2.7i build, though it was assembled by a knowledgeable friend. ECU & wiring harness is the 173 & Motronic 1.3. Injectors are M20B25 blues that were rebuilt by MEPEH. The tune is a no-name cam (that I dont think he's installed yet). Its temp fix until we can get the correct chip, but now its trying to get the car to a reliable point.
          Not sure about the other stuff, I havent seen the car lately
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          • ELVA164
            • 4861
            I see. I'm not super well-read on the swap, but a soft miss would suggest a fuel delivery issue and a hard miss would suggest electrical. OP, you may want to look into that as a next diagnostic step.
            • Das Delfin
              • Sep 2014
              • 2293
              sounds like a fuel pressure issue.. either your fuel pressure regulator or there's a check valve as part of the fuel pump. Does your fuel pump(s) make a loud grainy sound?
              • e30onBBSs
                • Dec 2014
                • 1347
                It only dies at idle? Once it dies it will just crank and not start until 30 minutes later?
                BMW tech
                Umass Amherst
                05 wrx sti
                • Est817
                  • Feb 2016
                  • 19
                  It completely dies at the idle. and then has troubles restarting/staying on.
                  after a good 15 - 30 min wait, it'll start back up no problem, and stay on for a bit before dying again. fuel pump does make a grainy sound. I'm thinking it's a fuel pressure issue. after looking into it, it seems to point to that more and more.
                  • ELVA164
                    • 4861
                    Maybe also a fuel tank vent issue? Fuel pressure goes negative because the vent isn't letting any/enough air in, then it slowly equalizes while sitting.
                    • 2mAn
                      Señior Mod
                      • 20689
                      updates?
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
