Battery always on, why?
  • FrictionTape
    • Sep 2016
    • 49
    With the battery connected, the battery light is always on, regardless if key is in the ignition or not. What could be causing the car to draw power continuously?
    Thanks!
  • e30onBBSs
    • Dec 2014
    • 1347
    Is the battery actually dying?
    BMW tech
    Umass Amherst
    05 wrx sti
    • FrictionTape
      • Sep 2016
      • 49
      Yes, battery is always on whether the key is in the ignition or not. Battery light on dash illuminated.
      • TobyB
        • 5280
        The 'battery' light is actually the alternator function light.
        Is it the only thing that's on?
        That would indicate a leaky diode in the alternator...
        ...if other things are working, you have a messed up ignition switch, or wiring...
        Assuming, of course, you have an E30.
        t
        • FrictionTape
          • Sep 2016
          • 49
          So yes, the battery light is on whether or not the key is in the ignition. It is the only light on when key is not In the ignition. Without the key in the ignition, nothing else works (as you'd expect). The battery eventually drains.
          • Das Delfin
            • Sep 2014
            • 2293
            could easily be a short in your cluster
            • FrictionTape
              • Sep 2016
              • 49
              Yes, but why is the battery dying?
              • Das Delfin
                • Sep 2014
                • 2293
                because there is a short in your cluster
                current draw = dead battery
                if your batt is 4 or 5 years old it will die faster as well
                • FrictionTape
                  • Sep 2016
                  • 49
                  [QUOTE=Das Delfin;4696001]because there is a short in your cluster
                  if your batt is 4 or 5 years old it will die faster as well[/QUOTE
                  OK...that's helpful. I imagine it's now a matter of testing the connections and looking for signs of corrosion.
                  • TobyB
                    • 5280
                    The cluster is dead when the key is off. But the alternator has a direct connection to the battery, and to the battery light.
                    t
                    • FrictionTape
                      • Sep 2016
                      • 49
                      t
                      Brilliant......thanks for the insight!
                        I'd suspect a failed voltage regulator in the alternator as the cause rather than a fault in the cluster. An easy check is to disconnect the exciter wire from the alternator. If the light goes out, the problem is in the alternator and new regulator/brush unit may fix it.
                        • FrictionTape
                          • Sep 2016
                          • 49
                          I'll check that out.....thank you all
