Cluster has gone crazy.
  • DeadCannon
    • Dec 2015
    • 12
    My temperature gauge had started reading high. After flushing the system the problem persisted, so we started trouble shooting the cooling system. Everything seemed to be working. One of the fixes I was told to try was to clean the contacts on the temp gauge. I pulled the cluster and cleaned the contacts. After that everything went down hill.
    After reinstalling the cluster, the temp gauge worked. And that's it. No tach, no speedo (which was already intermittent), no gas gauge but the gas light stays on, the left turn signal stays on, and when you put on the right turn signal the temperature gauge bounces with it. I'm at a loss for what to try now. I replaced the SI board today with one from Bavarian Restoration hoping it would help, but there's no change. The car runs fine other than a drain on the battery when it's parked. Since its not my daily it stays on a battery tender in the garage.
    Sorry if I rambled a bit, I'm just trying to relay any information I can think of.
    Lights off:
    Lights on:
    Sent from my SAMSUNG-SM-G925A using Tapatalk
  • MR E30 325is
    • Dec 2008
    • 3300
    A good place to start is with your grounds. Check engine grounds (primarily for good preventative maintenance) but also check your ECU grounding.
    That's all I have for you right now. Definitely an interesting one.
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • DeadCannon
      • Dec 2015
      • 12
      I went out and bought a new multimeter last night. I have no idea where my old one got to. I'll start checking pins tonight. If I'd thought about it I would have brought my Bentley manual to work for some light reading.
      • Gregs///M
        • Mar 2012
        • 2459
        This is a pretty odd problem especially the left turn signal staying on. This may indicate a short in the cluster wiring harness. Have a look at the three harnesses and inspect for insulation damage.
        I recommend tightening the 7mm nut behind the temp and fuel gauge. Also replace fuse 10, 12 and 21 with new 7.5A fuses and you may find everything working again.
        Good luck and remember all customers receive detailed troubleshooting help by emailing me bavrest@gmail.com.
        Greg
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
