trans drain bolt and ATF
  • Group A
    • Feb 2006
    • 201
    what size is the drain bolt on the auto trans of a 86 325. and what ATF do your recomend i should use, the car has about 250k miles btw
  • chuckybob
    • Aug 2004
    • 952
    the drain bolt is 17mm inverted. you pretty much need a 17mm hex.
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • AdamF 88iS
      • 2051
      Thats for a stick. The autos have a 5mm allen bolt.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Group A
        • Feb 2006
        • 201
        5mm? that seems really small too me. you sure it wasnt a typo for 15mm? and if possible, can you show me a pic of where the drain bolt is?
        • FredK
          • 14763
          Yes, 5 mm. Check the following link for a writeup on how to change the auto trans fluid in an E30.
          Find information, resources and relevant links for bmwe30.net. This domain may be for sale.
