Strange gas smell
  • M_3_X
    • Jul 2016
    • 162
    Strange gas smell
    Hi all.
    Not sure if it was a coincidence, but I replaced the fuel filter a few weeks ago, and next day, I started smelling a lingering gas smell in the garage.
    Went back and re-check all hoses, fittings, etc. but all is good, no visible leaks anywhere.
    I don't smell it while drive it or otherwise parked, just when it has been sitting in the garage for some time, I open the garage door and it goes away. It's more like gas fumes smell rather than strong raw gas leak.
    Would the charcoal canister produce this kind of smell? Any other ideas?
    "If everything seems under control, you're just not going fast enough"
    -Mario Andretti.
    ___________________
    River City Bimmers BMW CCA
    2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
    2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
    1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
  • TobyB
    • 5298
    unrelated leak around gas tank/filler...
    Gas can leak onto the top of the tank, and unless it's a lot, you'll never see it.
    t
    • M_3_X
      • Jul 2016
      • 162
      Good call, I will check that area. Any other way to check besides taking out the back seat and look under the fuel pump lid?
      -Mario Andretti.
      ___________________
      • straight6pwr
        • Sep 2004
        • 3450
        i don't mean to state the obvious, but, did you spill any when you did the work? dispose of the old filter in a garbage container and now that container smells? leave a rag around that has gas on it still?
        as well, I find things like this don't happen to be coincidental. you worked on an area of the gas system one day, then have a leak the next, its most likely from that area of work and not that you just happen to spring a leak somewhere else at the same moment.
        • 7pilot
          • 475
          Replace/re set your clamps at the filter. the former preferably, just in case a clamp has lost its tension.
          fuel is probably leaking when the system is pressurised, and bleeds off while the car sits.
          the leaked fuel vaporises and leaves the odour in the enclosed space.
          m
          • M_3_X
            • Jul 2016
            • 162
            Thanks for the suggestions, I will double check the clamps this weekend.
            -Mario Andretti.
            ___________________
