replace rear wheel hub?
  • s1uma1
    • Sep 2015
    • 304
    tried to change out my rear rotors and noticed that rotor screw was rounded (F*CK!)
    had to drill out but inadvertently damaged the threading on the rear wheel hub.
    Guessing i have to replace the hub now.. do i have to replace the wheel bearing also?
    or anyone have any tips?
  • s1uma1
    • Sep 2015
    • 304
    Gonna try to re-tap it
    • reelizmpro
      • 9558
      chase the threads or retap is your best bet.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • noid
        • 1537
        If you change the hub you have to at the same time change the wheel bearing as the inner race will likely seperate with the hub.
        You can chase the threads or get a time-sert kit.
        You can also ignore it, that little screw is only ment to hold the rotor in place to allow you to put the wheel on and align the lug nut holes. The lug nuts and rim is what actually holds the rotor in place.
        Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
        Your resource to tools and tips: www.rtstools.com
        • s1uma1
          • Sep 2015
          • 304
          Cool. Thanks. Ordered M8x1.25 tap and gonna give it a try... if it doesn't work I'll just leave it as "noid" suggested. Didn't realize he screw really doesn't do anythjnf
          • noid
            • 1537
            Taps can, but normally shouldn't be used to repair threads because they have a tendency to cut away fresh material.
            Use a thread chaser instead, they look like taps, but are meant for the purpose of thread cleaning and repair (gentle reforming).
            • reelizmpro
              • 9558
              Agreed. No biggy if you don't fix it.
              88 M3 - LACHSSILBER
              • CMatos
                • Jan 2017
                • 22
                +1
                I wouldn't bother with the retaining screw. Not worth the trouble. And yes, change the bearings if pulling the hub. Inner race always seem to separate.
                As a side note, the races are VERY easy to pop off. Take a grinder with a cutting wheel and score a notch on the top of the inner race. Then take an air chisel and hit the notch. It'll pop right out. You may get lucky and not have to even notch the race. They sometimes pop off with just the air chisel. Should only take a minute or two per race.
                Good luck!
                • s1uma1
                  • Sep 2015
                  • 304
                  thanks for the retap suggestions. it worked. =P
