2nd gear unreachable
  • chuckybob
    • Aug 2004
    • 952
    So I can hardly shift to 2nd at all. On the rare occasion that I can, theres about a millimeter wide window between not catching and catching. 4th is difficult to shift into, but still possible. 1st, 3rd, and 5th are all fine and dandy. its not like the synchro is broken, its like the "Catch" at the end of the throw in 2nd gear isnt even there. Any ideas? I was thinking maybe tranny mounts, but it seems like 1, 3, and 5 should also be effected if that was the case. OEM everything in the driveline, so its not those shitty IE bushings.
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Check your linkage and make sure nothing shifted around. This was the same problem I started to experience when my selector rod started to break at the shifter link end.
    • DanielHStout
      • Jun 2006
      • 294
      I bought my first e30 for $1000 because the owner thought the tranny was going bad. It turned out that the two bolts that hold the linkage to the tranny were just super loose. Tighten them up with an allen wrench and your good to go. make sure you use locktite though. I am 95% positive this is you problem if you have the older sheet metal style likage. You might have to lower the rear end of the tranny down a bit to get to them, it just depends how big your hands are.
      1989 325iX
      1995 540i
      1986 325eS R.I.P.
      1984 325e R.I.P.
