Wheel balancing with no balance weights on the rim?
  • Mixedbyjairo
    • Sep 2016
    • 103
    What's going on every one, the other day I got a pair of RS Reps (16x8) mounted and balanced to a bf Goodrich comp pro 2 (205/45r16) I notice that none of my wheels had weights, is there a new system of doing the balance or did they forget?
    Ps car seems to drive fine
  • e30onBBSs
    • Dec 2014
    • 1347
    No stick on weights no weights that tuck behind the wall of the wheel? None at all?? Occasionally a wheel and tire will be perfectly balanced with no weight but reallly uncommon probably like 95% need some weight in my experience...
    BMW tech
    Umass Amherst
    05 wrx sti
    • Mixedbyjairo
      • Sep 2016
      • 103
      None on all 4 wheels , when I was in the shop I asked if they forgot the weights lol , I really couldn't hear him but I thought he said it's inside the wheel
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5591
        Wtf? inside the wheel? like under the tire? If that's what they told you, that's some BS.
        • Mixedbyjairo
          • Sep 2016
          • 103
          Cool i thought I was wrong I'm going up there tomorrow and ask what the deal is.. there is a very light vibration around 50-60 mph. I just didn't know what it was cause I also need a lot suspension work
          • MrBurgundy
            R3V Degenerate
            • Mar 2012
            • 5591
            sounds like a wheel is out of balance lol
            • Mixedbyjairo
              • Sep 2016
              • 103
              [emoji23][emoji23]
              • crash n' burn
                • Nov 2014
                • 211
                The only wheels/tire I've ever seen not needing weights was pretty high end setup. My buddy had a custom set of work VS-XX made for his 370z and to balance them out, they just rotated the tire slightly on the wheel and it balanced out perfect.
                Dropping like $4500 on a set of wheels and tires, I'd expect something like that.
                -89' 320iT, Brilliantrot
                -15' 320i, Glacier Silver Metallic
                  • 34844
                  They are probably just stick on weights that are on the inside of the barrel.
