Battery discharge after heavy rain
  • AlexKing
    • Jul 2012
    • 62
    So car is a sedan with an m42 swap. Battery is in the engine bay
    After heavy rain the battery will almost completely empty. I have a rust hole in the cowl but from the look of it would only let water into the same place the black grille/vent things would.
    Another observation I made is that if the nose of the car is up it doesn't seem to be effected.
    I haven't got a multimeter yet but i will be getting one soon to help track down this but was just wondering where people would suggest i start.
  • TobyB
    • 5280
    ..plug the rust hole...
    Then check the alternator- it's always connected to the battery,
    and the diodes in it can start to leak current as they age.
    Then the usual trick- pull the fuses one at a time and check for current across each.
    You're looking for a drain of .050 amps or more- if it drains overnight, you're looking for
    a lot more than that.
    If it only does it wet, then you get to test it when it's wet...
    hth
    t
    • AlexKing
      • Jul 2012
      • 62
      hth
      t
      rust hole is getting plugged ASAP. Haven't been able to do it because of rain and other commitments.
      I think I have it fixed though, pulled out an aftermarket security system the other day and the battery has survived a massive downpour.
      I guess time will tell
